Autor Tema: SISTEMAS DE TELEFONIA BLUETOOH Compatibles Espace IV  (Leído 6425 veces)
Quiquelir
« en: 20 de Septiembre de 2005, 18:30 »
Alguien se ha instalado un manos libres bluetooh en la espace?. Me regalan un  Parrot ck 3000, sabeis sie s compatible?
Quique
Quiquelir
Pues si que es compatible
« Respuesta #1 en: 20 de Septiembre de 2005, 18:35 »
Después de buscar y buscar me autorespondo, parece ser que si aunque lo unico que he encontrado esta en ingles. Espero que os sirva
'CK3100 in Renault Espace 2004 with Cabasse Auditorium'
I couldn't find much on the net regarding fitting a Parrot CK3100 to a Renault Espace. Anyway, after a bit of investigation, and a few hours of work, all is working fine.
The CD autochanger is piggybacked onto the Cabasse Radio in a rear left hand panel.
Two torx screws removes the CD unit to reveal ISO connectors on the radio beneath.
The CK3100 can now be plugged onto these ISO connectors without any additional adapters or leads. The Red +ve and the Orange switched +ve wires do need to be swapped at the fuses.
The CD changer can now be reinstated.
There is one problem however. The Display and Microphone leads are now around 5 meters too short, and need to be extended to reach the front of the vehicle.
For this, I used a 5m VGA monitor extension cable (with ends cut off) following the wiring from the radio to the fuse area at the front (The VGA cable contains 3 seperately sheilded cores, 5 standard cores, and an overall screen). I removed trim along the passenger side (Right Hand Drive in UK) door step to reveal the loom, and installed the VGA cable. The microphone was installed in the ceiling. The remote, just to the right of the steering wheel. All connections were made just below the fuses in the dash.
I used a sheilded core for the microphone, leaving the rest of the VGA for the 7 cores required for the remote display.
If done properly, there is just enough cores to extend the AUX Audio In, as shown at http://www.planeterenault.com/forum/viewtopic.php?t=4019 allowing you to run SatNav audio or an iPod via Aux.
Hope this helps anyone contemplating installing a 3100 to their espace (maybe other Renault models as well).
Regards
Keith
Desconectado MAREANEGRA
« Respuesta #2 en: 20 de Septiembre de 2005, 20:23 »
YO TENGO EL PARROCKT NO SE QUE MODELO Y VA DE LUJO.
Socio Nº.4 Getafe (Madrid)
G.Espace 2.2 initiale.
ESPACEKILOMETRICA
« Respuesta #3 en: 22 de Septiembre de 2005, 12:22 »
Yo me he montado un Nokia 616 y es fabuloso, es mucho más caro que el parrok pero me gusta más
pacoespace
« Respuesta #4 en: 26 de Septiembre de 2005, 21:59 »
He montado un PARROT CK 3100 y no solo es perfectamente compatible, sino que es muy sencillo de montar. Aunque eso si muy laborioso.
Va de autentico lujo. En breve mandare unas fotos de donde y como se ha instalado.
Desconectado admin0
    • http://www.clubespace.com
« Respuesta #5 en: 26 de Septiembre de 2005, 22:10 »
Entre el Nokia 616 de kilometrico y el Parrot CK 3100, pues me quedo con el primero, claro, pero ya se sabe... "con duros, castañas".
Ambos son buenos.
Desconectado admin0
« Respuesta #6 en: 26 de Septiembre de 2005, 22:12 »
Por cierto kilométrico ¿cuanto te sablearon por el Nokia 616 ya instaladito?
El Parrot CK3100, pacoespace lo acaba de comprar y montar por uno 150 euritos, que no está nada mal.
ESPACEKILOMETRICA
« Respuesta #7 en: 26 de Septiembre de 2005, 22:22 »
Lo que es el NOKIA 616  410€ + iva y el montaje 60 € iva incluido, lo compre en REDCOM en el mes de Julio , tiene unas prestacione muy altas podeis verlas en la web de nokia.es
ESPACEKILOMETRICA
« Respuesta #8 en: 26 de Septiembre de 2005, 22:23 »
voy a poner unas fotitos para que veaís lo bien que esta ubicado.
Desconectado marmotagl
« Respuesta #9 en: 27 de Septiembre de 2005, 09:24 »
ya he pedido mi parrot ck 3100 para cuando llegue la espace instalarlo, con los puntos vodafone, 1800 puntos y 64€ con instalación, un chollo.
« Respuesta #10 en: 02 de Octubre de 2005, 02:04 »
Tengo montado el 3000 en un audi a6 y va bastante bien, el sonido es bueno, algunas veces se hace un lio con la sincronizacion con la pantalla del equipo alpine, cortas el contacto y lo vuelves a poner y a correr.
El sistema se encarga de todo, la compatibilidad es para que te aparezca la agenda en el display del coche y no tengo informacion al respecto, pero en alpine solo funciona con nokia (yo tengo sony-ericson).
Es todo lo que se del tema, pero yo hace dos años cuando lo instale busque un telefono en la web de parrot francia y aqui en españa me atendieron de lujo, si tienes dudas busca en esa direccion.
En la espace tengo un tomtom 500 que como manos libres bluet es razonable, pero estoy pensando jubilarlo y meterme en otra historia...
